Having problem with my jk e-power
Hello guys, I have installed 4 warn lights with the 2 stck fog lights, power plant winch, 6 spekers, 2 subwoofers, 2 amplifiers, capacitor for the sound system and rancho remote control for the shocks. My question is what shall I do to prevent my battery from draining? I was thinking to install another battery but I Realized that there is no enough space to indtall another one. I dont know what shall I do. Give Ideas please guys. Thanks
Get a yellow top Optima battery. They run about 150 - 200 depending where you get it. You won't have any problems. Or if they make aftermarket ones yet. You could replace your alternator. I'd go with the optima though.
I also recommend the Yellow Top Optima, but I don't know about upgrading the Alternator. If I remember correctly (and if I don't someone here will certainly correct me..) the stock Alternator is a 160 amp unit. As automotive alternators go that is pretty high amperage. While there are higher rated ones out there they aren't cheap and may not be all that easy to integrate into our computer controlled JKs.
There aren't any kits that I've seen yet, but I'd say a two battery system would be your best bet with an isolator as you suggested.
Be the first to put one together! You can use a kit for a TJ, the only thing that isn't going to work is the tray probably. Need to find a place to remount the batteries.
If your battery is draining, with the jeep running, you'll need to upgrade the alternator, or run dual alternators. In my opinion, the only reason to get a second battery would be if you wanted to listen to music, or shine your lights, while the engine is off.
Otherwise, unless you're a crazy off-roader, there's really no need for a second battery. The stock system is pretty stout, so unless you're running the winch, trying to get out of a ditch with all of your lights on, and your subs blaring full power, and the jeep off, you shouldn't need to do anything.
