Hardtop defrost question
K so I just self installed the Hardtop wiring kit. Everything is in fine. Wiper and washer fluid both work. But when I push the defrost button up front it doesn't stay on...it immediately turns off. I have not yet taken the jeep to the dealership to have the VIN updated in the ECU as the directions say. So, does it sound more like I wired something wrong, or is it because of the defrost not being able to work due to the VIN in the ECU?
I am experiencing the same thing even after dealer 'flashed' my CPU. I re-checked all my wiring for my defroster circuit (DB/WT to CAV 32 by replacing wiring already in cluster and black ground solid). Wiper works as it should. Did you get your CPU flashed and everything work? I'm thinking they didn't do mine right.
