Ground wire help
Ground wire help
So I was removing my hid kit. Well I wasn't paying attention and broke the stud where they put the ground wires. I move it to the bolt the holds the bracket for the power steering. All should be good right? If not how to fix. I drove the jeep and all seamed good I just wanna be sure
I don't see why it wouldn't be a good choice. If you have concerns about it being enough, you can always run some low gauge wire (10ga) from that ground spot to another one or drill a hole in the frame and run your wire to a bolt there.
Again- I would think what you've got is sufficient. If you notice accessories acting up, then maybe consider adding the additional ground wire to what you've got.
Sent from my DROID4 using Tapatalk
