Got some HIDS
I hope you don't drive in crappy weather often. You will be blinded by stray light from them. I am removing mine next week. First snowfall of the year and it was down right scary driving in the jeep. Wall of white and no projected light. Now, in my hella 500 driving light I have 55w hid kit and it's like daylight. But for the main headlight on the jeep hid is useless.
If you have a HID projector retrofit kit, those do an amazing job. Huge amounts of light, all directed where you need it. And they're no worse in snow than any other properly designed headlight. Oh, and they are perfectly legal in all states.
Personally, I'm keeping an eye out for what Truck-Lite is releasing at SEMA. If that puts out a more even light pattern than the original Truck-Lites, I might have to spring for it. If not, I'll be picking up a HID retrofit kit shortly.
Yes. I know the retro kits are good but I don't think that's what he has. Then with the retro kits you still got to screw around with wiring and trying to get them to work.
I used a 55w kit from vvme. Just install and then your good.
As for how hard they are to install, the answer is 'not very'... assuming you're willing to pay for it. The XSighting Xe7 is a drop-in replacement, but it's not very cheap. On the other hand, it is street legal. A DIY HID retrofit kit is kinda-sorta legal and will run around 1/3 to 1/2 the cost of the drop in kit, but it takes a good bit of effort to get it set up right. And then there are the bulb replacement kits like VVME sells, which, while cheap, are most decidedly not street legal and can get you a pretty hefty ticket.
I have HIDs in my H4 e-Code lights and have no problems in the snow at all. There is a decent cutoff.... BUT - the glare is still there. I am looking to retrofit my lights soon if I can build up the guts to buy the stuff and tools lol.
