Good place for an amp in a 2011 Sport Unlimited?
Old 07-25-2011 | 11:30 AM
pickjones's Avatar
Originally Posted by seventrys
I mounted mine on the back side of the flip down rear seat. There is a metal frame under the carpet. Self taping screws held it in place.
Got pics? ....
Old 07-25-2011 | 11:51 AM
atc22's Avatar
I have mine in the trunk under the Sub box that I had built, it sits about 4in off the ground so the sub fits nicely under it and you dont even know its there. You said that you are keeping the factory stereo so I m guessing a subbox isnt in your future. My opinion is you can put it in any of the above mentioned places and then put a piece of matching carpet over it so it blends in better. A local stereo shop should have a piece of carpet that will match! I replaced my entire system and tried to make it look as inconspicuous as possible since I like to keep the doors off. Here are some pics of my sub box (amp is under it).
I have had three stereo systems stolen, all you can do is try to hide your stuff as best you can but if they want it its theirs! I had an alarm on every car it never seems to help just maybe slow them down.
ID:	186004   Click image for larger version
Old 07-25-2011 | 01:26 PM
blancolex300's Avatar
Originally Posted by Brashanic
Mine is in the trunk compartment. It therms out after about 45 mins of loud play. It takes less than five minutes to comeback online. It kinda sucks
I'd be interested to know as well. There are a lot of extraneous factors that may be causing that, from too small power/ground wire, poor ground, etc.
Old 07-25-2011 | 01:35 PM
scotty6336's Avatar
Well someone wanted to see a pic earlier of my setup, which I claimed to be safer to water crossings, and naturally no more than 1 hour ago a HUGE storm came through with sideways rain and soaked everything....So currently its drying out in my shop
Old 07-25-2011 | 05:41 PM
roxbury29's Avatar
nice sub.. forgot to post - - 2 10's DVC subs - powder coat'd sub box
Name:	sub box dual 10 (Small).JPG
Old 07-26-2011 | 09:45 AM
seventrys's Avatar
Originally Posted by pickick
Got pics? ....
I have a tuff trunk so I put a sub in the trunk area and ran the speaker wire under the back. I did not mount it to the back of the tuff trunk because it is removable and did not want the amp getting in the way.
ID:	186355   Click image for larger version
Old 07-26-2011 | 11:11 PM
fastrat350's Avatar
Mine is mounted to passenger front seat, used two angle pieces of aluminum mounted to the seat frame and my amp sits between this. My amp is a jl audio hd900/5
Old 08-11-2011 | 08:09 PM
FowlerJE's Avatar
Default Good place for an amp in a 2011 Sport Unlimited?
I've got one mounted under each front seat. Nothing to fancy, gotta clean it up and re-mount but all in all a good location.
Old 05-02-2012 | 09:13 AM
Bunk's Avatar
Go under the passenger seat. Keeps the rear seat capable of folding and gives some decent air to the amp....AND hides the amp!
Old 05-02-2012 | 09:40 AM
isolated1523's Avatar
Is there not a spot inside the dash under the steering column to mount an amp? Thats where the stock infinity amp is, at least for 07-10s. It where i mounted my PDX5 as well...
-Adam
