Fuse for Fog lights ??
What is the fuse called on the inside of the fuse box or the number of the fuse for the fog lights? Sorry for the ridiculous question, but I cant seem to find it. Maybe I'm looking over it to fast...
Iv looked at the fuse box layout map also.
https://www.jk-forum.com/forums/show...fog+light+fuse
Any help would be great, thanks.
This is just a thought. But since there doesn't appear to be a fuse for the headlights either. And both of those systems are controled by the PCM. And the PCM monitors current draw to those systems. Then, in a round and about way, the fuse for the fogs would be the PCM fuse. I work with "PLC's" Power Logic Controlers in the industrial world. And they usualy have one power supply to control many systems. Why do you ask?
If the fuse for the PCM was bad I would assume I would be missing more than my fog lights. The reason for me asking is I installed my DDM 35W Hid kit, which I hoped for it to be as simple as plug and play. When I turned the lights on one of the bulbs flashed, 5 seconds off,flashed, 5 seconds off, then flashed and stayed off. Sounds like a bulb out error? I then added the error eliminators from DDM and nothing happened. I then put my stock bulbs back in and they would not light, they both worked when they came out.
Thanks for the reply
Well just to follow up, I had to run out and when I came back I thought I'll plug in the stock lights and see what happened for fun. And well they worked fine guess I must have reset something some how... Anyway I'll be adding a relay for my fog lights and have them all installed by the weekend. Headlights already installed and working just fine.
