Which fuse?
Which fuse?
Last night I hit the switch for my PIAA fog lights. The lights flashed on then went dark. I think a fuse might have blown but I'm no expert. Can't find an aux fuse position on the fuse box diagram of my 07 JK. Does it sound like a fuse problem, if so where might I find the potential blown fuse position?
whoever installed the lights should have put a fuse in the line. Take a look around the relay that came with the PIAA lights.
Just saw the previous post about the bulbs. I've had tesr lights for less than a year and already replaced the bulbs 1 before. If it's the bulb doesn't that sound like excessive bulb replacement? Twice in a year. I rarely ever turn those lights on.
My PIAA were only 3 weeks old and when I turned on one day/night both lights burned out. I thought it was the relay or fuse and tracked it down to the bulbs. I took off the lens and noticed the bulbs were burnt out...........
My jk had no original fog lights. I replaced 1 of the bulbs (which was blown )and that light is working now but the other light (bulb is good) isn't working. WTF is going on?
