Fuel Pump Relay Switch location
I have a 2013, manual, that has shut down on the highway three times. After it sits for 20-25 minutes, it starts back up, and runs perfectly fine. I'm thinking it could be the fuel pump relay switch, however I can't figure out where it is located in the fuse box. Can someone please help? Thanks.
Thanks, ronjenx, based on it shutting down, occasional not starting, and occasional burn '13 has a plug in relay, and through deduction I found its location. Will see if this fixes problem this weekend, it'll get a bunch of miles.
https://www.jk-forum.com/forums/stoc...-353243/page7/
