front view cam questions? any one with a pyle view cam out there?
I am installing camera with my loc pic 2 front 1 rear, The rear comes with a ground the front do not not that i can tell they are pyle view they have a video cable a power wire and then there are 3 wires that are supposed to be to change the view from front to back and to remove the distance lines these are supposed to be red white and black but in reality they are blue white and black.
Questions do all cams have to have ground?
if so could the black wire with the other 3 be the ground?
In the instructions there is o mention of a ground wire, so I am confused, ?
What do you guys think>
I have this camera on the rear of my Chevy 2500 it has a ground wire. I love this camera, I got it on Amazon for under $20 and it has worked for over a year now so I'm happy with that. I would recommend putting the camera's on switched power so they only get power when they are being used. If you run constant power to them than the life of the camera's life will be shortened drastically.
got it figured out
so I installed 2 front view camera and one back up camera with my lock pic it is way cool. the 2 fron camera are in the cut out of the w on my warn bummper backed with lime green cutting board, and the rear is in the bumper.
