Front LED Turning Signals
Old 11-26-2016, 07:38 AM
JBryce19's Avatar
Default Front LED Turning Signals
Hello all,
I am planning on installing Oracle Plasma Halo Lights and would like my front turning signals to be LED also. I've researched quite a bit and can't seem to find anything other than the Recon Smoked LEDs which get horrible reviews and seem like a hassle with resistors, wires corroding, and all of that.
Any ideas?
Also has anyone installed the Oracle Plasma lights? If so, any feedback, comments, pros, cons???
Thanks
Old 11-26-2016, 09:56 AM
ronjenx's Avatar
Do you have your text in white? I don't see a thing in your post.
Old 11-26-2016, 11:08 AM
JBryce19's Avatar
This should fix it, the non mobile version has a black background so I'll stick with color I guess.
Old 11-26-2016, 05:43 PM
j_w_thames's Avatar
I am also interested in such an option--can't believe there's nada.
Old 11-26-2016, 06:20 PM
fultonromero12's Avatar
I'm also looking to upgrade and I was considering these. The good reviews far outweighs the bad. Any thoughts?
Old 11-26-2016, 06:23 PM
jchappies's Avatar
I use the amazon LED turn signals with no issue, no flickering either.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11-26-2016, 08:08 PM
thechad07's Avatar
Default led signals
I got creative because the plug and play options were less than optimal.
Old 11-27-2016, 04:06 AM
Eddie Man's Avatar
Originally Posted by thechad07
I got creative because the plug and play options were less than optimal. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=661682"/>
Please share your awesomeness.
Props !
Old 11-27-2016, 10:29 AM
shabbernigdo's Avatar
i just wired in resistors then bought clear factory housings so i can use switchbacks. run white till you signal then flash orange.
Old 11-28-2016, 08:40 PM
thechad07's Avatar
Default Front LED Signals
I knew there are many 4 inch round led signal options available for trailers and big rigs that mount in a rubber grommet the fits in a 4.5 inch hole.
Basically, I found a JK grille on Craigslist for cheap to practice on. I trimmed off the turn signal bucket with a dremmel. Then I centered, traced and opened up those holes where the signal buckets were to 4.5".
Quick Reply: Front LED Turning Signals
