Foglights on with high beams
Do you ever want the fogs to turn on seperately from the high beams?
Do you want the fogs to be wired to the high beams permanently?
Do you want to be able to shut off the fogs while the high beams are on?
All of the above are basically the same question, just different ways of thinking through the operation and functionality.
What is your goal? It is fairly easy to permanently wire the fogs to the highs, or wire up a seperate switch to control the factory fogs (might even be possible to use the factory fog switch but that woudl require some digging).
You need to think the design through.
The Mopar wiring harness will let you hook up your lights with highbeam with a switch. It will not turn on unless your highbeems are on. (Since most lights are for offroad use only).
1 Post
Honestly I would say have the fogs setup on their own switch and not even wired into the headlight setup.
This way you can turn them off and on when ever you want plus they will stay on highs or lows.
I have my fogs set to my lights on my superduty but it turns off with highs and it's all good since my lows provide foreground lighting and I just angled fogs to be between high and low beam coverage. Now I don't ever use high beams.
If you add in the relay. And switch it with the high beams. You will not necessarily need another switch. The only possible problem would be that you would get your fogs on everytime you switched on your high beams. You would have to add an "off" switch to have selectability over that issue. But I actualy aggree with the other guys. I do not believe that fogs are a good match for high beams. That is why I am currently running driving beams with my high beams. If you do a little research on beam patterns and their intended use, you will see what I mean. But if fogs are what you want. I will be more than happy to assist you.
I wired my Hellas this way for a short time. I changed it back for many of the reasons/questions posted here. Also it's illegal. I'd suggest you wire a relay and an in cab switch to have them on or off depending on conditions (snow, fog, rain etc)
I am very curious about the legal issues with opperating fog lights with high beams. No one seems to have a problem with operating other beam patterns with high beams. What is the diffrence? Some people say that it is a weather related issue. OK, then what are the atmospheric conditions that must exist befor you can legaly opperate your fogs? And How are we to know when the conditions have been met so that we can legaly use our fogs?
Using the fogs is pretty much a commen sense thing, and is dictated by the weather conditions. In a blinding rain, snow or heavy fog, the normal driver should slow down. Since the fog light has a very short wide pattern, this allows the driver to see directly in front of him providing he is driving at a safe speed for the conditions, as well as see the roadlines and markings off to the side. When these conditions arise, it might also be prudent to turn on the emergency flashers. This would allow any oncoming driver to see the object approaching him a bit better.
The standard for fog lights in the United States is SAE J583.
During a recent convention at the National Highway Traffic Safety Administration (NHTSA) the following was pointed out,
" Studies have shown that in North America more people inappropriately use their fog lamps in dry weather than use them properly in poor weather."
If you want a good read about fog lamps, look here. http://www.danielsternlighting.com/tech/lights/fog_lamps/fog_lamps.html
Last edited by HappyCurmudgeon; 10-08-2010 at 04:48 AM. Reason: Removed hyperlink - See FAQ's
Most states have their own law about this. For example here in Pa, it is illegal to have your fogs on with the high beams, and on the other side of the coin, driving lights with low beams. ( this is normally checked during the required annual state inspection, at least to me) I would guess in states where it is illegal to marry your sister, is this way also, that is why in the stock configuration the fogs are set to go on with the lows, and automatically go off when you switch to high beam. This is for safety. Since the fog pattern is a wide beam and puts most of the light in the immediate foreground, having them on at night with the high beams would blind or dazzle an oncoming driver far more than the high beams alone (we all know we should switch to low beams when approching an oncoming vehicle), and possibly inhibit the driver of the vehicle with this setup on to see any great distance in front of him or her.
Last edited by HappyCurmudgeon; 10-08-2010 at 04:50 AM. Reason: Removed quoted hyperlink.
