Fog lights w/ high beams?
ok, someone tell me why the fogs (factory) turn off when high beams are selected?
i drive at night with fogs on at all times. great lighting. was driving up
to sister lakes in michigan through woods so i was like, hey! lets
put them high beams on so i can see better! ya rite, damn near couldn't
see anything. whats up with that?!
Eternal ***erator
In a lot of states it is illegal to drive with the fog lights lit when the high beams are on (or the converse, Driving lights with the low beams on), so it comes that way from the factory. I don't know about Illinois, but in New Yuck it is not supposed to pass the yearly inspection if they are operable with the High's on, and if a cop wants to dig for a ticket on you, it is an easy one to get you on.
On the older Jeeps there was an easy jumper setting you could do to allow them to operate, not so on the JK's, it is controlled somewhere within the computer and isn't easily bypassed. It can be done, it just takes a lot more effort now.
Eternal ***erator
so you know how to do it
hook us up!
plEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEZ
I do not even know the last time I had the headlights on high beam.... The fog lights and the headlights, then when I get to the really dark spots, I use the KC lights. But am working on replacing all the bulbs in the headlights and the fog lights with the Xenons or Sylvania white lights
Eternal ***erator
There is no mystery to it, just wire them to a seperate relay. Exactly like you would any other aftermarket light. You need the same old stuff that comes in the box with any light kit on the market: a switch, a relay, a fuse/holder, and some wire/terminations. Like i said, a lot more effort than adding a jumper, but pretty simple also.
I tried to get this done at a dealership here in Canada and they said no because it would disable the day time running lights.
