Fog lights
Fog lights
What is the brightest bulb that i can buy for the factory harness? While replacing the bumper thought I would upgrade while I had easy access to them. It would have to be something you could grab locally since the planned day for install is Wednesday.
research!!
Do some reading on Danielsternlighting.com. Learn about the CANBUS interference issues. OEM fogs are only about 35-40 watts each. You can run greater watt bulbs; but you should isolate the power circuit via a relay (with capacitor and diode protection if you want to use your OEM stalk mounted fog lamp switch) and proper fuse and wire size protection.
Love the avatar jingles. Yeah I just wanted some plug and play lights and not have to put flux capacitors and crap. I will give it a read though. I guess the simpler question is maximum wattage with no issues.
