Flickering Fogs
Flickering Fogs
I recently mounted my 6" HID fog lights onto my Mopar Light bar...everything worked fine
A day ago we had lots of rain and I used the fogs on the highway on the way home
Today I turned them on and as I accelerated, the lights started to flicker than turn off.. I stopped the Jeep and turned them back on and they worked....I shook the bar and pulled on the wiring to see maybe something was loose...Nothing
I looked at the bar where I mounted the ground wires to and I saw rust...I used a black anodized self tapping screw to keep the ground connected to the bar
I am thinking this could be the cause of the flicker?
U didn't paint the screws after we screwed the grounds on??? Put some paint on it too. Hopefully it's not the plug inside the bar
U might need to attach a ground wire from where the bar bolts on to the frame.
Sounds like a loose connection somewhere.. Check the bolts on the sides of the bar.. Just saw u called guessing this is why.. Lol.
Ok so yesturday i was cheking the wiring and turned on the lights and 2 of the three didnt turn on I turned off the lights and turned them back on and all 3 lit up
how is this possible if all three are wired together?
