Fix for soundbar speakers?
#21
How about trying to swap front channels with the back channels? That should put full power to the rears.
Or maybe a parallel hookup with another stock amp and and use the front output to drive the soundbar speakers.
#22
Just to update this thread....there is a fix, thanks to member " aero instability " in this thread
Basically, you replace the JK Infinity amp with a Dodge Nitro amp, Mopar part # 1-05091012AF.
HTML Code:
https://www.jk-forum.com/forums/showthread.php?t=39623
#23
weak soundbar speakers fix
i too hate the sound that 'doesn't' come from the soundbar. i searched on this site and found 2 solutions of which i'm willing to try:
1. someone posted a thread on changing the stock infinity amp to the amp that comes in a Nitro. cost him about $250, but said it corrected the issue immediately
2. another person posted a reply on this same thread that when he did the TSB 'speaker pop' recall, it immediately corrected the problem as well and now has full sound from his soundbar. this is a 'flash' that they do that updates the software. costs $0 due to the TSB
i can't find the thread, but it's hear, search 'nitro amp swap' or something. i need to go into the stealership for a soft top issue, but i have the TSB for the speaker pop and will have them address this with the 'flash' as it's the 'free' option. i'll let u all kno if it pans out...or not...
EDIT: oh wait, there's the thread in the post above mine! D'Oh! methinks the answer lies in here folks...
#24
I get it tomorrow. I will post my results on the other thread.
#25
How bout a fix for those without the infinity system?
#27
#28
I'd recommend trying to get the flash performed, then see if it sounds good enough. If not, swap out the amp. Then the speakers.
