Father in Law just gave me his Mopar Kicker sub and I have a question.....
so he gave me the sub out of his JK because he didn't care to have it. My unlimited has no sub installed currently. Do I still have the wiring harness back there? Is it plug and play? I do not have the infinity system......
I haven't found anything through search yet. Thanks for any help for this newbie!
You will need to get the amp (that is mounted behind the drivers shin panel), and the wire harness that goes with it. It will work with any of the factory systems. These sound great, and are easy to remove if you need the cargo space.
Ok, I just wanted to get a little more info before we do the swap this weekend.....
So he has the infinity system, with (what I'm guessing) is the stock infinity sub mounted in the back on the right hand side. He also has the kicker upgrade woofer which is mounted to the back of the rear seat. My question is if I take the kicker sub, the amp under the steering wheel, and any wiring harnesses......will it affect his other speakers and/or the other sub that is back there?
Thanks for any help you can provide.
Removing the kicker sub and harness will not affect the factory setup the harness for the kicker is completely seperate from the jeeps factory harness
harness should start at the battery come across engine bay at back of hood in through cowl to amp from amp down kick panel and then all the way to the back on inner drivers side tub
