Is the factory sub with enclosure worth anything?
I am going to be removing mine and upgrading to a 10 inch sub with custom enclosure, and was wondering if this infinity is worth anything. Thanks for all input.
JW
JW
Are you asking is it worth something to someone else? I bought one on ebay, I wanted to keep the stock look and space.
You could always change the speaker out like some others have done on here. That is my plan in the near future.
Also-Is there carpet behind it when I take it off, or metal? If its metal, I probably wont take it out.
Thanks
I think I paid around $75 for it. Mine had carpet with slits cut in it for the sub so I would feel sure you would have carpet behind it. There are 3 nuts, 1 at the top near the roll bar and 2 on the base. Once you remove it there is a connector on the back to disconnect the wiring.
