Factory HU Pin Diagram
I can only see it as a way to tell them apart.
Edit: I take that back - after closer examination I think you're right - they do look slightly different. The I's on the bottom of the connector are wider apart.
So perhaps the initial statement of the C2 and C3 being the same is not correct, although the pin-in's are the same.
Oh ok, I see what you're saying. I imagine this is just to differentiate the ports? If you notice in the pic of the actual connectors, one being white and the other gray, that they are exactly the same despite the ports being in the configuration you described.
There I go again -- Posting Mis-Information
I'm headed to my dealer tomorrow... They are the ones that gave me the part numbers. I'll bounce this off of them and see if I can get the correct part number for both connectors.
07 wrangler after market reciever
Hi All new to the forum but have owned jeep wranglers for years the older models were easeir to wire, my question is i am throwing away the stock head unit and bout a nice doble di unit to fit it's space, wiring is easy for the radio but the tomtom gps has 3 wires that need to be hoocked to speedometer any thoughts on how they could go, i noticed when i removed the old unit there was a connector taped down from factory, this could be used for the uconnect if upgrade was availible i am guessing, any help would be appreciated as your forums are the best and more defined than any dealer I have encountered
Stock HU unknown to me 1 cable coming out to old stock radio, I will have to look closer at the pin number once I disassemble, but my question, there is a small connector looks like they prewired for some thing that could be used as a add. this may have been used for the infinity stereo not sure any ideas would be helpful, thanks Ron
