ESP light on, how to turn off?
Old 09-05-2013 | 08:20 PM
CenCalJeepster's Avatar
Default ESP light on, how to turn off?
Bought my jeep used and lifted. Previous owner said after the lift, he had the dealership turn off his ESP and that's why the dash light on the dash is on. Is there a fuse I can pull or anyway to turn the dash light off?
Old 09-05-2013 | 08:40 PM
Jersey_Devil's Avatar
If ur esp was just off every time u start ur jeep it will sound a chime and instead of miles it will say "esp off" on the odometer....the previous owner fed u a line...could just be a wheel sensor that bad tho
Old 09-05-2013 | 08:41 PM
Rmjr's Avatar
Mine came on yesterday. I got out my superchips programmer & checked the code then cleared it.
ID:	495311   Click image for larger version
Old 09-05-2013 | 09:44 PM
This is what is on all the time
Old 09-05-2013 | 10:39 PM
karls's Avatar
Steering angle sensor points to the clockspring, but I deleted the code, centered the wheel up a little better, and haven't seen the code since then.
As to it being on all of the time....
-start with the steering wheel position, make sure it's right
-do the "steering wheel dance" in hopes of re-enabling it
-check wheel sensors.
If you've got a superchips then read the codes and see if you can skip to step 3.
Sent from my GT-P5113 using Tapatalk 4
Old 09-06-2013 | 03:03 AM
metaldemon's Avatar
It if is an earlier model the dealer could have done the steering wheel dance to turn it off. It won't work on a '12 and up. If that is the case, doing it again will turn it back on. But he may have turn it off because off the lift.
Old 09-06-2013 | 04:28 AM
jwilson2598's Avatar
Sounds like something is not quite right after the lift and rather than fix it, he turned the ESP off. I've had 2 lifted JK's and never had to disable ESP, so something is amiss in your setup.
Old 09-06-2013 | 04:45 AM
justin22's Avatar
If its disabled it will stay on. Google jk esp disabling and turn it back on.
Sent from my SGH-I337M using Tapatalk 2
Old 09-08-2013 | 02:18 PM
Yeah it's an 08 and lifted. He said after the lift, the ESP would turn on or something do he had the permanently have the dealer turn it off, which is why the lights on.
So can I pull a fuse or do anything to turn the light off?
Old 09-08-2013 | 02:37 PM
karls's Avatar
There are a couple fixes....
- figure out the issue and correct it, then re-enable the ESP
- cut up a folder and tape it behind the dash over top of the light.
Both will take some trial and error but the second is much cheaper.
Sent from my DROID4 using Tapatalk 4
