Electrically Challenged
I would like to hook up 3 different sets of lights. Factory fogs, driving and spots located on the windshield pillars. So, I have 3 sets of lights, 3 switches and a ton of wire. I am confused as to the best way to do this. Should I establish an auxilery fuse block? Should I simply hook them up independently and use the supplied relay's? What is the best method of making this a clean job? Any help is a plus because I have looked at this for hours and have not been able to get anywhere.
Eternal ***erator
This is what i am currently doing.
I wired New 6" fogs to work off of the factory stalk switch, way easier than it sounds to do if you have the factory fogs already.
I have 2 more sets being considered now. An auxilliary fuse block would make a cleaner install, but isnt necesary.
Where are you stuck?
I'd use an aux fuse block, and relays. JK came with factory fogs, and I wired in some driving lights. The driving lights are powered with a relay, tripped by the high beams. Relays are really not difficult, just pay attention to the diagram, and wire gauge.
