Easy wire tap for CB near center console?
Old 04-14-2015, 01:44 PM
auceny's Avatar
Default Easy wire tap for CB near center console?
I'm planning to install a Uniden 520 cb in the center console and was wondering if there is a very easy place to wire it in to? I assume the cig lighter in the console would require tearing the whole thing out and not be THAT easy. Maybe wiring under the seat or at the front of the console near the dash?
Or maybe the fuse box? I really have no idea about wiring accessories up.
Old 04-14-2015, 05:59 PM
kmrtnsn's Avatar
Quadratec sells a power tap in line that accesses the 12V power plug on the dash, it takes all of 15 minutes to install.
Old 04-14-2015, 06:11 PM
auceny's Avatar
Any idea what it's called or a link? Trying to find it now. Thanks!
Edit - Is this it? http://www.quadratec.com/products/96080_9801.htm
Old 04-14-2015, 07:09 PM
kmrtnsn's Avatar
Originally Posted by auceny
That's it. I recommend you look at their center console CB mount too.
Old 04-14-2015, 07:16 PM
auceny's Avatar
Can't find that one. I was just planning to mount it to the rear of the inside of console with the upper tray removed.
Old 04-14-2015, 07:22 PM
ronjenx's Avatar
That's a nice harness, and it's certainly better than the squeeze-on blade taps a lot of people use.
It's not the only way to add switched power, as the description repeatedly claims.
https://www.jk-forum.com/forums/jk-e...source-189556/
https://www.jk-forum.com/forums/jk-e...source-191552/
Old 04-14-2015, 07:24 PM
kmrtnsn's Avatar
Quadratec Exclusive JK-CBM11 - Quick Disconnect CB Radio Mount for 07-15 Jeep® Wrangler & Wrangler Unlimited JK with Uniden Pro 510XL Radios - Quadratec
Old 04-14-2015, 07:31 PM
auceny's Avatar
Ok yeah I saw that but I think I'm just putting it inside the console to be secure and out of the elements.
Old 04-15-2015, 01:33 PM
auceny's Avatar
Is this really a 15min job? I ordered it then looked at the instructions online and it shows tearing the whole dash apart.
Old 04-15-2015, 07:15 PM
auceny's Avatar
I think everything is installed other than the power. Waiting on the wiring from Qtec. Click image for larger version
Quick Reply: Easy wire tap for CB near center console?
