Easy Switched Power Source
#61
So, my question is, do you see anything else getting delayed power?
If yes, that needs to be troubleshot as a separate issue.
If no, the fuse tap connection has to be the culprit.
#62
From what I can tell nothing else seems to be delayed. I have since replaces the fuse tap, and currently no fix to the situation. I am now looking at my realy, bc my tap is switching my relay, so possible my relay is not activating or powering me fuse block. Thoughts?
#63
SO far this is working with my 2012 JK when i turn over the key. It had a 20 AMP in there but i took it out and but in this fuse tap with a 10 AMP. Now my question is and its probably stupid but where would my 3rd power outlet be if i had one?
#64
My work computer is not allowing me to edit my post so ill add another one with the addtion of my last one.
My owners manual says where i put the fuse tap is for power outlet #2 BATT/ACC select. So is this the 3rd power outlet you are referring too or is this one of the 2 that are located on my front panel and storage compartment between my seats?
#66
#67
For those with the 2012 and do not need the M7 Power outlet #2 BATT/ACC fuse there is where i put my fuse tap into. The power outlet #2 is for the rear power outlet or known as the 3rd power outlet. My JK does not have one so i do not know why there is even a Fuse inside that slot. So far seems to be working well. It had a 20 amp in there but with the fuse tap i put in a 10 AMP as my bully dog programmer suggested to use a 10 or 15 AMP fuse. I also included how i ran the wire and where it came out of the fuse box so i can hide the wires as much as possible. I ran it behind the wiring on the backside of the engine bay so you can not even see it. I am going to go out and find a rubber grommet to put around the wire to help keep dirt, water, and whatever else out but have the ease of taking it out so i can take it to the dealership for warranty work.
Pics of fuse tap in the slot. * * * is the 3 holes that you can use to put a fuse in and i did mine like OP did and used the *[*][*] holes to put the fuse in. Far right closest to the driver side.
Wiring leaving the Fuse box.
#68
In the M7 spot there is a 20 amp fuse, will putting a fuse tap with a 10 amp fuse blow the fuse or cause any problems? Sorry about the late post, I was referred to this thread.
#70
The 10 amp fuse will blow only if more than 10 amps tries to go through it. (From too big a load, or a short between the fuse and the load.)
