DVD when driving
Old 01-05-2012, 04:37 PM
Rotbag's Avatar
Originally Posted by Ryan0260
I used a toggle switch in my last vehicle to bypass the switch
What exactly are you bypassing? I may try it on the wife's Jeep.
Old 01-05-2012, 07:58 PM
jesse0376's Avatar
From what I have heard u need the lockpick unit on my pioneer avic z1 all you do is ground out the ebrake wire. Don't think it will work for the stock units
Old 01-05-2012, 08:01 PM
arasco85's Avatar
i downloaded one of the software updates. it has a glitch. you can watch while driving with a hit of the menu botton.
Old 01-05-2012, 08:05 PM
ac1brooks's Avatar
Originally Posted by jimmydarnell
Thanks. Looks like I can find a lockpick on Ebay for around $120. I like the factory look so that would be best. Any body installed one? How hard is it? How long should it take?
Mine took about an hour & a half to hook up & run back up camera & hook up my headrest tv's, but I like to make sure all my installs are clean & wires all hidden. If you just wanna hook it up & not all the other stuff I would say 20 minutes
Old 01-06-2012, 08:56 AM
qzing01's Avatar
Just ground out the Green parking brake wire and done!
Old 01-06-2012, 09:03 AM
EAZY-E's Avatar
The lockpick is the way to go if you have GPS. It allows you to set destinations without being stopped and unlocks the DVD while in motion. Install took me about 30ish min. The most difficult part is stuffing the wad of wires back in with the whole mygig unit. Other than that a 5yr old could install it. All of the plug ins are one way connections and cant be mix matched.
Old 01-06-2012, 09:27 AM
Ryan0260's Avatar
On mine it was a switch that works off the parking brake. It only let it work if the brake was set. Toggle=easy fix. However I do believe it is illegal to have an operating TV in the drivers view while driving
Old 01-06-2012, 09:55 AM
2saharas's Avatar
Default Is it legal?
Check your state law. In Nebraska as well as several other jurisdictions it is illegal to have a television in view of the driver while the vehicle is being operated on a public roadway. $100 fine in Nebraska.
Old 01-06-2012, 11:32 AM
Rotbag's Avatar
Thanks guys. Didn't even think of the legality.
Old 01-06-2012, 02:02 PM
stryke-force's Avatar
It's only illegal if you get caught
Quick Reply: DVD when driving
