Duracell AGM Deep Cycle Marine and RV Battery
Need to get a new battery and found a Duracell made by DEKA battery for a $110.00 at Sams Club. Looks likes it would be a good battery for the price.
Battery specs
•20 amp hour rate:55
•BCI Group Size:34M
•CA at 32 degrees F:955
•CCA at 0 degrees F:775
•Reserve Capacity:120
Link to battery specs
http://www.dekabatteries.com/assets/base/1741.pdf
Thanks for any advice
Battery specs
•BCI Group Size:34M
Battery specs
•BCI Group Size:34M
Battery specs
•BCI Group Size:34M
How about the warranty?
My Sears Platinum has 48/84 which is awesome, but it also cost more.
Thanks
What i found is that the Automotive AGM battery is 36/84 and the Marine AGM is 18/72. I like the terminal connections on the marine battery which has dual posts. One set of regular battery posts and one set of 5/16 studs which make it easier to connect winch and lights to. The terminals on the marine battery are stainless steel as well.
Thanks
Thanks
Thanks
Thanks
This is from their site: 4-year free replacement and 100 month pro-rated limited manufacturer's warranty
