Dual battery set up
#81
I am going to be getting this install started now that it is a bit colder here and wanted to check on a couple last things.
Im assuming I'll need 4 terminals but I was wondering what lengths of power/ground and how many power/ground rings I would need.
Thanks
Also does the cole come with a switch?
Thanks
#82
Thanks
Thanks
And the Isolator comes with three 18AWG wires that extend out of the "black box" portion of it. The black on is a ground, the violet one is for a boost switch that you can use to temporarily connect the two batteries manually, and the white one is for an in-dash led status indicator.
I hope this helps!
#83
This isn't the one that came with the kit. The one that I recieved with my Benchmark system was the Cole Hersee 48525 which is the 85 amp model. I went through two of these. The first one I zapped and the second one just stopped working. I started thinking that the 85 amp model was not sufficient with the alternator being about 115 amps so that's why this third one that I purchased and is currently installed is the Cole Hersee 48530 200 amp model. And ever since installing it, it hasn't worked as it should. The other two worked fine for at least a while before they failed.
as for working as it should it does not isolate untill the MAIN BATTERY is drained down less then 12.7 V for 1 min or more
#85
http://www.quadratec.com/products/17004_200.htm
Painless has a dual battery set up for about $150 (cheaper if you search around). My plan is too get this kit and a RR tray. About $250 total for what I've found...
#86
I wouldn't hesitate to purchase and install another Benchmark setup, regardless of the posts I've read. I am extremely happy with the quality of mine, and in the end, that is what your paying for. I realize getting it fast is nice, but I consider some things well worth the wait. This is one of them.
