Dual battery set up
#31
#32
Originally Posted by sheepdog
Did you receive your kit or at least an update?
#34
Originally Posted by boricuajc
Have n't received an update from them yet. Ordered it on 4/25. Funds were taken on 4/27. Just sent them my first email for an update.
#36
How have you folks been making out with getting your dual battery kits from Benchmark? For those of you that have recently gotten your kits, were they complete? I'm looking to do a dual battery in my JK, really like the Benchmark and don't have anything pressing where I need the kit quickly, just don't want to get stung by either not ever getting it or missing pieces. I've recently emailed them asking about availability and lead times, got no response. Hate to be actually needing something from them and be treated this way. If you weren't to go the Benchmark route, what would have been your second choice?
#37
I've been looking at a couple other setups, both require you source you own battery tray:
hxxp://store.adventuretrailers.com/products/Split-Charger-Kit%7B47%7DDual-Battery-Kit.html
and this one JK specific (with in cab winch controls):
hxxp://www.12voltguy.com/product.php?productid=17552&cat=258&page=1
Second one requires you also provide neg batt cable and battery cable clamps for 2nd battery.
Like the Benchmark but not up for dealing with lousy customer service, way to many negative threads in that regard.
#38
#39
Well my package arrived this morning. If the rain holds out, I'll try installing this weekend.
I plan on using my almost one year old Optima Blue top with a new Blue top that I'll pick up after the install.
Anyone forsee a problem using an older battery with a newer one?
Should I use the older battery as the main battery or the Aux battery?
#40
Unless the batteries are identical and the same age, one will always get a better charge than the other. The one with the lowest internal resistance gets the better charge.
But, I've gotten by with mis-matched batteries and just put up with the uneven charge. It works, just not as well as it should.
When you have an opportunity or an excuse to put in new matched batteries, just do it.
If winching is important, I'd put the best battery on the winch. It takes more power to run the winch than to start the Jeep.
- Bob
