driving lights switch placement HELP
I was hoping for some opinions on best switch panel. Read alot of reviews on daystar lower switch panel having less than stellar fit.i also like the a pillar switch panel but havent heard good or bad on it. Thinking about just using provided switch but dont want to drill holes in a 9 month old jeep. Thanks in advance
I recommend plasmaglow or plasmaglow knock off switches on the A-pillar. I got mine on superbrightleds for $5 ea, you can fit 3 easily in a row, more if you think ahead
Edit: I drilled into my 3 week old Jeep, very nerve racking but the outcome was great
Thanks ill check into those the factory KC Lites switch looks kinds bland. Is there a good place to ground the switch behind the a pillar cover or will i have to run an extension somewhere. Thanks again
You don't have to ground anything in the cab if you got a harness, it should just ground in the one place near the battery and there are plenty of options there
For just me using the switches, I like the little plasmaglow switches. I'm constantly having people go turn on "x" light. With the OTTRAW switches it took the guess work out of which switch turns on what, and that's why I went with them. Plus they have that factory look/feel. I used the factory panel.
