Driving lights install??
Need you help. I am installing a pair of long range driving lights on a Pro-Comp light bar and would like to know where y0ou have found the best spot on the firewall to go through? I need to get my switch wires to the dash>
Can anyone share what you have found to be the best point of entry?
Thanks for your assistance. Cheers.
'08 Wrangler Unlimited
On the driver's side on the top portion of the firewall there is a grommet that has some wiring going through it that if you fish the wire through it and to the right when looking from the front of the vehicle at the firewall the wire will end up inside the cabin nearest the clutch pedal.
