dome light mod.
Old 02-05-2010, 09:51 AM
nclehmann's Avatar
Originally Posted by njbeachrat
yes its pretty simple...just use a flat head screw driver and from the oposite side of where the hinge is (between the black and the clear lense) push it in slightly to get it off the small lip holding it in
So they both just pop out? No screws?
Old 02-05-2010, 09:53 AM
Dr.McNinja's Avatar
Yep, the only thing holding it in is the tension of the clear lens. Once you pull the lens down, you can get the whole assembly down.
Old 02-05-2010, 09:59 AM
dmhines's Avatar
I'd like to do this mod in my 2-door ... anyone know if there is constant power under the soundbar in a 2-door. Twisting the switch for the dome light does suck ..
Old 02-05-2010, 10:54 AM
njbeachrat's Avatar
not sure on the 2 door...
but if you have to turn on the dome light at the steering wheel instead of push on push off at the sound bar it probably is not constant...to make sure, pop the lense cover down if there are three wires coming out of the bulb then it has a switched and constant....
Old 01-19-2011, 10:26 PM
hotdogging's Avatar
Originally Posted by cbloyer81
Has anyone put the 2010 dome light in yet?
Edit: I thought the 2010 or 2011 had buttons for each side of the vehicle. So the passenger and driver got independent light. I just looked at the Jeep website and the pics didn't show that. Did I recall this wrong?
Bump for anybody with info and a part number
Old 01-20-2011, 09:44 PM
hotdogging's Avatar
Bump to the top...
Old 01-20-2011, 09:56 PM
NH-JK's Avatar
I have. A 2010... No go in the dual side light. Just plain old middle.
Old 10-28-2011, 06:52 PM
rinkishJK's Avatar
I never got around to doing this, but I do have a led board in the front dome light , and no rear one at all now and it's great for me.
I have a home made trunk, so I put led strips inside of the back area so I can see, and I did the footwell led mod too with led strips and the inside has lots of light, as well as the back.
Old 11-04-2011, 09:00 AM
2008blkjeep's Avatar
Had a 2008 shara, purchased a 2010 center domelight. Ran a hot all the time 12 volt wire to it. Just pluged the wire into the connector that had no wire in it. Worked great.
Quick Reply: dome light mod.
