Do I need the factory antenna?
All I listen to is the satellite radio and the big ugly factory antenna, as far as I know, is only for AM/FM signals. If that is correct then I should be able to just remove it and not have to worry about it. If anyone knows any different let me know, thanks in advance
Thanks guys, i think I'll probably order a stubby from antenna x but until i do I'm just going to remove the other one. Tails and car washes are a nightmare with that thing. Appreciate the responses
Or just chop yours. I cut mine to 15", popped the ball off the top, glued it to the now shorter piece and Plasti-dipped it. I haven't noticed any reduction in signal when I have listened to FM.
I agree if your not really into FM/am cut your stocker with a pair of wire cutters pull off the ball & super glue it on you'll save money & still have a little radio
