Delta headlights
Delta headlights
Hey does anyone have the delta headlight? Thinking about buying, how do you like them?
Does anyone know if the rugged ridge headlight guards will install over them?
Tried the Delta Quad Bars in my 2008 Rubicon and was not satisfied with the beam pattern. Ended up giving them to a friend and installing the Cibies (H4) and using the upgraded wire harness from Susquehanna Motors Sports. Very pleased. With the new harness you can use higher wattage 100/80 or 130/100 in the Cibies.
