Ddm tuning 7" conversion
Anyone tried these new housings Ddm tuning makes? It says you can run hid's in them..
http://www.ddmtuning.com/Products/7i...nd-halogenLamp
Sent from my Nexus 7 using Tapatalk 2
Can you run hid bulbs in them yes, will the light be focused correctly no. ONLY way to get Hids is using a projection Hid capsule, either a correctly done retrofit or get 90mm Bi-Xenon High/Low Headlamp Kit for replacement of Factory H13 2007> Jeep JK Wrangler Headlamps. - Headlamps - Lighting - Browse All Products - Susquehanna Motorsports
