Daystar switches
Daystar switches
Is there anywhere that might stock the switches that fit in the Daystar switch panel? By that I mean somewhere I could grab one tomorrow. I have a set of lights to install and I want the switch to fit in the panel I already have. Thanks in advance!
Any 4WD around you? Northridge 4x4 also has them, but your location says LA.
An alternative is going to an auto parts store (Auto Zone) and getting a cheap temporary one that you replace when receiving the Daystars.
No I hadn't considered them. I'll have to check them out. I didn't end up having time to install the lights. I painted the bumper and now I am chasing the toddler around the house. Thanks for the suggestion though. I have a little time between now and next weekend to check those switches out before I get to install the lights.
YES! Get those. I just installed two of them over the weekend. Look awesome. Light up green with dash lights and then red light (or other combination) when turned on. Plus they look a lot more stock.
Attachment 285444
Attachment 285444
Thanks!
Steve
Some of the electrical supply house's. Or the electronuics supply house's carry these switches. They wil sell "over the counter" without a contractors license. You can also try the Marine supply house's.
Just ordered two of the OTRATTW switches..."FOG LIGHTS" and "NAV LIGHTS". I should have them in a couple of days. I assume they will fit the Daystar lower switch panel.
Thanks for the suggestions. I think these are going to look much better than the plain Daystar switches.
