Dash lights going crazy, I've tried everything
2008 JK. Dash lights are going crazy. Coming on and off intermittently. I've done some research and tried possible fixes but nothing is working. Tested battery. Good battery. Two new different sets of battery terminals. Reset my TIPM twice, once overnight. Checked fuses. Checked my grounds. Bought new ground wires and added more. Disconnected my sway bar plug and fuse. Can anyone help me out please?
Also the ABS/ESPBAS lights have been on for years dude to faulty wheel speed sensor so I believe those are irrelevant to the other dash board lights going off. See attached video of my dash.
Have you pulled the TIPM out and checked the various connectors on the bottom of it? Disconnect, give a very careful inspection of all of the connections and pins and sockets, clean and reassemble. If that doesn't help, you may have a TIPM going bad.
