Custom sub box ideas??
#112
I built my own sub enclosure - I've been building boxes for years and through trial and error have gotten pretty good at it.
I based my design on the Quadratec enclosure- www .quadratec.com/products/14136_3904.htm
However, after speaking with the box builder who makes these for Quadratec, I wasn't thrilled about the limited depth for the subwoofer, nor was I thrilled with the fact that they used only 1/2" MDF in its construction. 1/2" MDF is just insufficient for high performance systems.
With a few tweaks in the design dimensions, I modified it to accept a single downfiring Kicker Solobaric L7, with appropriate airspace.
I used 1" thick Ultralight MDF in the box construction, which substantially increases the box acoustics and performance - you'll need to source this through a specialty lumberyard or cabinet shop - it can't be found at your local bigbox home center.
Mounted in the amplifier slot to the lower right of the box is a JL Audio HD 750/1 - It is the perfect amp IMO to push the L7 Sub.
Under the box in the storage area is a JL Audio JX360/4 4 channel amplifier, which seats perfectly in the storage area. These 4 channels push my 2 sets of Rainbow Audio's CS 265 X-Plain Pro component system 6.5" speakers in my dash and soundbar.
It was a pricey system and was a time consuming install, but the end result was nothing short of amazing sound - especially for a JK.
Attachment 273812Attachment 273813Attachment 273814
https://www.jk-forum.com/forums/show...b-Possible-Amp
#113
Originally Posted by Brashanic
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=195620"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=195621"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=195622"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=195623"/>
Good luck!
Good luck!
#114
Originally Posted by PLATOON
Mine is more of a gun case than a sub enclosure. I have 2x down firing 10" JBLs in sealed compartments in the front of this box.
#115
Im in the process if building me a box. But I have a 10 inch polk audio sub. And a 1000w audiopipe amp. And multimedia head unit with 7inch touch screen. Has usb,aux, and sd card slot. Plus it plays dvd. And all my 6 1/2 are Sony.
System sounds amazing for how much I have in it.
#116
When you remove the passenger seat, is there anything special you need to do regarding air bag stuff? I'm thinking of mounting my amp here as well, and I just don't want the air bag to go off while I'm removing the seat or break it's functionality for when it's really needed. Is there just a plug or something?
#117
#118
I was wondering the other day can you build one with enough air space that sit flush to the wheel well? I know nothing about subs and boxes but that would be good use of a wasted space. If you wanted two subs you could put one on either side. Make em flush with the rail.
