Cube led picture request...
Old 11-07-2013 | 05:36 PM
GeckoTY's Avatar
Default Cube led picture request...
Hi everyone, I'm planning on running 2 small cube LEDS on each side of my 4x4 adventure rack basket(garvin industries) as work lights. I prefer floods of spot because I don't need long distant, just a wide range...
Does anyone have a pic they can post of just 2 cubes on & nothing else and can tell me there opinions on what kinda set up I should do like what brand and such... Thanks!
Old 11-07-2013 | 07:28 PM
White Ghost's Avatar
I don't have any but seems like everyone choose rigid industries d'2s
Old 11-07-2013 | 08:16 PM
NewJKontheblock's Avatar
Trying to upload pics but keep getting errors...running rigid duallys as my fogs and D2's in the pillars
Old 11-07-2013 | 09:42 PM
JKphotoshoot's Avatar
Probably not much help but this is 4 dually floods and headlights.
Old 11-08-2013 | 10:21 AM
Sami@inspired-engineering's Avatar
Former Vendor
Here is a picture of one single CUBE light of ours, in an otherwise dark field. This light is in Flood pattern.
Here is two CUBEs in spot pattern
Old 11-10-2013 | 07:11 PM
GeckoTY's Avatar
Awesome thanks!!... What harness would I need for my 12 jk? Also, I saw that your flood pattern is 90 degrees... Did I read that correctly? How do they mount? Is there a tab/bolt on the bottom side of them?
Old 11-10-2013 | 07:40 PM
DannyMalkin's Avatar
Find some cheap ones, these come with wiring but you could probably find even cheaper ones if you search.
Off Road CREE LED Light Pods 2880 Lumens Flood Pattern with Wiring Harness | eBay
Old 11-11-2013 | 06:37 AM
GeckoTY's Avatar
I'm not really worried about the price. .. I'm a firm believer of you pay for what you get. I just don't want to waste the money if the outcome of the leds isn't what I'm looking for.
Old 11-11-2013 | 05:56 PM
chad s's Avatar
they make a bracket that fits in factory position. They make a custom bracket for the 10 a front bumper which is what I have. They look factory with great light out put. Very pleased with them. Can't beat price. If used in stock position they are plug and play
Old 11-12-2013 | 12:29 PM
Former Vendor
The 2012 JK uses the PSX24W connector. Yes, our flood is 90 degrees, They have a u bracket standard which allows you to mount them however. The U bracket has a nut and bolt on the bottom. We also have brackets that place them in the OEM position.
