cruise control & AC
cruise control & AC
Hi all, have a 21011 wrangler jk rubicon. problems with steering wheel controlling the cruise control switch been replaced twice, clock spring, and still intermittent dealer found a bad ground while replacing oxygen sensor that helped the cruise work consistently longer, but now back to same original problem codes P0579 & P0581. How many grounds are there to affect this switch.
AC and reverse lights now don't work, I fond compressor clutch not kicking in, applied12v direct to compressor wiring and clutch worked and system supplied cold air, checked for continuity ad A connector and have power to one side and system running at 35lbs pressure.
My ol 92 dodge Dakota had the AC and the reverse lights on the same circuit, and since I don't have the factory owners manual can't identify them from the fuse panel cover under the hood.
