Converting Fog Lights to LED's
I purchased a used 08 wrangler earlier this year, and it had some aftermarket fog lights installed onto the bumper, from what I can tell is the previous owner had cut the fog light wires & put spade connectors (think that is what they are called) and attached what seems to be a (knock off kc light) h13 light
. If I was wanting to convert these to some type of led fog light , do yall think id be able to just solder & shrink wrap the new cables together?
not sure if led pods would run off factory cables.
only reason i want to change these is because they are very yellow and dim its almost not even noticeable at night when they are on.
