Connection for reverse lights in trailer included with Mopar 7 pin trailer harness?
I have the towing package which includes the 4 pin connector. I plan to add the 7 pin harness to gain the 12 VDC connection for the battery on board the trailer and a heavier ground than comes with the 4 pin harness. The trailer (Jeep Extreme Trail pop-up) is light enough that it doesn't need brakes and so I will not be installing a brake controller.
The trailer has backup lights and I would prefer that they operate when I am backing the trailer.
Those of you with the Mopar 7-pin trailer harness - does the backup lights on your trailer work?
Thanks for any information.
I have the 7 pin and 4 pin also, the reverse lights on trailer should come on if you are plugged into 7 pin. The dealer had to flash computer when I had 7 pin installed so that system would expect to see the current draw from the trailer lights. Doug
Really? I haven't done this (didn't know I needed to) after installing the Mopar 7 pin kit myself and haven't had any problems.
The Jeep came with the towing package and the 4 pin connector so I'd believe that the computer would already expect any additional current draw. The trailer has a 7 pin plug and I used a 7 to 4 pin adapter to drive the trailer home. The brake, running, and turn signals worked well.
Rather than convert the trailer to 4 pin, I would like to add the 7 pin harness to the Jeep to add the 12 volt power and be able to activate the backup lights. I also have a Tundra that when I connect to the trailer provides the 12 volts and turns on the backup lights when I put the truck into reverse.
What I am looking for is postive feedback that the Mopar 7 pin harness includes the connection from the backup lights on the Jeep to the harness.
Thanks,
Kent
