Concern about new Light Bar
Ground wire
The lights can all share the same ground wire. But I recommend you run a positive wire for each light. Doing this makes troubleshooting a problem easier. Plus if one light go's out they all don't go out. Yes space looks limited but it can be done with a little drilling and some time.
If you run the power wire to the positive terminal of the first light, and then from the positive terminal of the first light to the positive terminal of the second light, etc., one light failing will not cause them all to go out. Additionally, assuming the mounting bracket is bolted into structure which it should be and since there are currently 5 wires for 5 lights, each light should be grounded directly to the bracket. In other words, I'm pretty sure I could wire the whole array up with one wire.
I thought about actually grounding to the mount as you recommended. I'm not sure if thats a good ground but it would probably work. Running one common Positive would work but would require a lot of soldering. To me its easier to just run the 5 lines down the tube to the relay with one common ground. Great thing about DC electrical is along as the electrons can make a full loop back to the source the way you wire it can be whatever you want.
Looks Awesome!!! I really Like JCR bumpers looks really sharp. I really hope you find someone who can do it right. You have a nice looking Jeep no need for sub-standard work to be done on it.
Either way, the Jeep is looking great!
My work and family schedule (3 kids playing sports) keep me from doing projects like this one. Actually sent two posts about my jeep while sitting in the stands today. Time is money, and right now I had rather spend the money to have the family time. Thanks again to everyone helping people like me in this forum. The Jeep community is truly awesome!
