Complete stereo system rebuild.
Old 01-04-2012 | 03:35 PM
  #31
jkirkpatrick's Avatar
Originally Posted by Crparks
No sub. I may add one down the line but so far I haven't found a spot to put one without sacrificing cargo space. And I need to save up a few more bucks. I will probably build a box to hang on the inside of the tailgate with a couple of 8s but first I want to research how strong it will be. I run with a 35" spare I'm already nervous about that. I'm also toying with the idea of making a custom box and "hanging" it on the back of the front seat. Both front seats actually. Am going to research how big it will need to be and wether or not the seat back will hold it.
Not Jeep specific, but my second last system I went with a dual 8" setup vs a single 10". Never again. Great for "punchiness" but no real low bass out of them. My current is a single 10" and should I ever do a proper sub setup in the Jeep, I'd opt for a single 10" slim profile sub vs dual 8's, with the sub hanging off the rear gate.
Old 01-04-2012 | 03:45 PM
  #32
ninjamaster's Avatar
Do you guys think it would be possible to fit a JL 10 W0 in the stock sub housing?
Old 01-04-2012 | 04:57 PM
  #33
Patman's Avatar
I just built a box for my polk audio db840dvc (8" inch) that sits behind the driver seat. It is not bolted down, as I like to keep it removable in case I need the storage. If I go somewhere that could cause my sub to bounce around, chances are I'm not going to be blasting my music and won't need it and can secure it somewhere else or take it out
Old 01-06-2012 | 04:50 AM
  #34
PhantomRescue's Avatar
Default Nice Advice
Glad to see this thread has some very useful information! Bought an Alpine CDE-126BT last night and also picked up the C2R-CHY4 adapter harness as well as the antennae adapter cable, all things listed as being required for install After reading most of what has been posted here I am not sure whether or not to use the harness or just take it back and save $200. I don't have the amp or sub in my JK and do not plan on adding either of those down the road.
Any pics of the installed replacements you guys have, post 'em up! Would like to see how they turned out.
Old 01-06-2012 | 01:55 PM
  #35
Crparks's Avatar
A few different people at a couple different stereo shops say no chy4 necessary in adding after market amp and HU and wiring. After giving it a lot of thought, it makes total sense. All new = no need for factory harness.
I just got the last of my stuff in the mail today so I'm going to be diving in here directly; maybe as soon as I sign off here. First step, find a home for amp. I'm thinking under passenger seat. That will be the shortest run for power.
Old 01-06-2012 | 02:01 PM
  #36
Crparks's Avatar
If you are staying all factory except for head unit swap, you need the module, but not necesarily the chy4 and not necessarily from a retail store. Check the web and search for alternatives.
Old 05-21-2012 | 07:34 PM
  #37
Soundwave's Avatar
I've also upgraded the head unit , I have the factory amp and sub so I bought the chyah07 module . My problem is when in Acc mode the stereo works but when I start the jeep it is says no signal , when I go back to Acc it still has no signal?? I've racked my brain with the wiring and I have no idea! Any thoughts? Not much info on exact wiring on the "intraweb"!!!
Old 05-21-2012 | 07:41 PM
  #38
TJM12's Avatar
Weird. The headunit might be faulty because it isn't recognizing signal yet it is the source player?
Old 05-21-2012 | 08:00 PM
  #39
Soundwave's Avatar
I was thinking it might be a ground issue or parking brake bypass issue ?
Old 05-21-2012 | 08:06 PM
  #40
TJM12's Avatar
Do all source modes work normally untill you start the jeep? Does the unit power down when you start it up?
