code reader
code reader
Does anybody in the long beach area have a code reader I could borrow to check my dash lights? Don't wanna pay almost a hundred bucks just to check the code. Haven't had any luck with the key trick to have the code display on the dash. Thanks in advance
LB you have 5:13 gears ... you have a programmer? Most programmers are DTC readers too. Figured you would being you would want the Jeep to know it has 5:13's especially an auto... just a thought
Cant you do it by cycling from 'ON' to accessory 3 times, landing on 'ON'?
I did that to pull P0111 code for my CEL in mine a few days ago.
Edit: "Haven't had any luck with the key trick to have the code display on the dash." Oh, never mind...
No I wish I had a programmer but I haven't picked one up yet. None of the auto zones by the house will read it for free but they say that have a code reader that will read off just the code for $60 so I may just go bite the bullet there. Thanks for all the advice everyone. Wish the ignition trick worked on my JK
