Clutch Bypass Relay Wiring
So I tapped into the yellow/red wire for the clutch relay, attached a momentary switch. Works like a champ, however about every other time I use it, I get a check engine light and a P0835 code for the clutch safety switch. Wondering why it's not every time I use it. Why am I getting the code if the original wiring is still intact? Any ideas?
2016 JKUR
2016 JKUR
Can anyone please confirm what wiring harness the clutch interlock is connected to? I am doing a manual swap and I am needing a part number for a 2015 jku. If I am correct, it is the wiring harness that the horn/abs is on also? Called the "Dash wiring harness" too many part numbers with mopar for what seem to be the same thing. Any information would be appreciated. I am sorry for being off topic. Couldn't find any forums giving needed info. TIA
