Circuit breaker question
I bought a wagon gear relay block for the my 2012. The Idea is that I will relay all of my accessories off it. (BTW, its very nice and I highly recommend it.)
http://www.wagongear.com/WiredWagon_...layBlock_1.JPG
I would like to have some sort of switched Circuit breaker/Relay/? between it and the battery so that when the key is turned on this relay block become "Hot." I have seen these before, but cant remember where or what they are called. Suggestions?
I would probably use a relay for that...
A relay has two sides:
a switching side, (which activates the relay contact)
And a current side (wires that are connected when contact activates)
Depending on what you will be running, you might be able to pick up a
general aux fan relay kit, usually 30A or so.
For the wiring, the switching side would tap into a wire on the ignition that is hot with key on, other side to ground, and on the current side would be the hot wire from the battery to the relay other side relay to panel. The panel ground would go directly to the battery.
Also make sure there is a fuse inline on the hot wire from the battery that runs to the relay...closer to the battery the better.
Make sense? Although i assume NO RESPONSIBILITY if you try wiring and fry something..
So it would go: 12V SWITCHED POWER SOURCE====TO TOGGLE SWITCH======TO RELAY++++RELAY TO LOAD ??
The primary power ( for lighting ) would be supplied from the battery.
