Chip Key?
Chip Key?
I was just wondering if there is anyway to get rid of the chip key, and ring on the ignition. I am just wondering if it is possible. Just trying to avoid more electronic issues down the road.
The chip in my key went bad once. You could bang it around and it would work sometimes. The spare key still works. I'm not sure if you could switch it to "chipless" but you can buy a new key for $15 on amazon and have a stealership program it for around $50
See post #2 in this thread.
https://www.jk-forum.com/forums/stoc...e-keys-174902/
To an extent you can get rid of it. Fastening a key to the column, under the plastic, will allow you to insert and use any regular key so long as it is keyed correctly.
Replacement keys are $6 on eBay and home depot cuts them for free, programming is also free provided you have two current keys. You may have up to eight keys.
The sensor is around your ignition and it just looks for the chip ID from your key. That chip prevents a theft even if someone has a copy of your key.
Former Member
WHY?
If you do it then me and every other owner will live with the stats of how easy a Jeep is to steal and our rates go up.
Don't be silly and f... your friends.
Let's get real here. You drop a chip key into the column. 16 year old kid that's never heard of a chip key pops your key cylinder and drives away. Hits another vehicle and runs. Guess who's in s..t when they figure out how he/she was able to steal it so easily
