Check Engine code P0137
So, bought a 2012 in excellent condition from a reputable dealer (oxymoron?). All is well for a week till I fill up mid grade from a slightly less desirable gas station and the check engine light came on within a day. I successfully pulled the code from the "turn the key three times" trick and got "P0137", which seems to refer to an O2 sensor. Is it possible bad fuel would prompt that fault? (I checked the gas cap, etc...).
