Change front speakers
WAnt to change out front speakers and any info on where to start do I have to take the whole dash apart can only see the screws on the bottom it's a 08 jk
Do an Amazon search for 77kick10. This is the Mopar upgrade speaker kit. You can download the instructions for replacing the front speakers. They are very clear and straight forward. Hope this helps.
While changing out the speakers will help some, if you just have the standard HU, you will not really see a lot of improvement. The stock HU just does not have enough power to make any good speaker sound good. For the best result, need to switch out the HU and the speakers. Then if you really want to get some great sound, you will have to add an amp, etc. May sound like a big job but with a little work it can be done. I am big on keeping my 2011 JK as close to the factory look on the inside while still upgrading components and I was able to do just that.
