CB antenna hood mount?
Old 04-03-2008 | 07:11 PM
User 12721's Avatar
Default CB antenna hood mount?
Hi all,
I'm looking for a CB antenna hood mount, and I have looked everywhere, but I can't seem to find one that will fit the JK. All I found is the Firestik one made for the TJ. Anyone know of one?
ColinW
Old 04-04-2008 | 02:59 PM
mdantonio's Avatar
Hi Colin! NOT a problem. Just get an NMO roof mount with a 90 degree feedpoint connector on the bottom-end. You will also need to get an NMO style antenna to fit it though. This arraingment may look a bit goofy once it's actually installed though. They also make a bracket mount that fastens between the hood and the fender that isn't (A) As goofy looking and (B) doesn't require drilling a 7/8" hole in the center of your hood. We use them all the time on radio installs for Fire Chief's, etc. They work fine! Take care... Mike
Old 04-04-2008 | 04:07 PM
pitcoken's Avatar
Or consider using the passenger side windshield bumper hole in which to mount the NMO base! I prefer to use NMO since they are inherently water resistant when the antenna is removed. They can be made water proof with an inexpensive screw on cap. Regretfully I have never seen an 11 Meter antenna for NMO! If you find one, please post it here! The NMO is common for VHF and UHF Ham antenna.
Old 08-30-2008 | 11:04 AM
rubiconjack's Avatar
I've already got a firestick antenna. Just bought it last night ...
anywhere else they sell like a universal hood mount.
I don't have my rear tire carrier anymore .... so where else could I put the antenna ... Hmmm ..
Old 08-30-2008 | 11:18 AM
okay .. i justanswered my own question ... just going to make a bracket and screw it in the holes where the carrier was before .... figure something out!
CUSTOM MADE
Old 08-30-2008 | 07:47 PM
rickc309's Avatar
Just buy a magnet mount base. They work well.
Old 08-31-2008 | 07:35 PM
User 12721's Avatar
Hey jkgirl, if you don't want to make your own you can look into the stainless one at CFE products...cfeproducts.com/jk-jeep-wrangler-antenna-mount.html...I have this mount and it comes with both stainless and nylon shims that fit behind the mount, where you use the stainless ones if you have the tire carrier mounted and the nylon ones if you don't.
Old 08-31-2008 | 07:51 PM
possumface's Avatar
all u need is a pc. of aluminum bent to a 90 degree angle with a hole in it to fit the antenna, i used a couple self starters under the between front hood and front fender. this was before my cb was stolen
Old 09-01-2008 | 07:19 AM
hmmm possum. Sounds like if it was really bolted down that would've worked. Imay give that a try.
I took my rear tire mount off .... I have thought about a magnet base, it'd work great with my winch mount on the front, as my winch is upside down ... just the way it went on with the stock bumper manipulated .. but having the antenna in front of me ???
LOL! ROFL with it being on my hood. I may try it .. I know theres a nother threada that wants to see it ...
Old 09-01-2008 | 06:47 PM
TBJK's Avatar
WTF what is the world coming to. stealing a cb? must have been some punk kid looking for kicks.
Quick Reply: CB antenna hood mount?
