Can I make the radio stay on longer than to sec after engine is off
If you have the EVIC you can change it in personal settings from what I've read. Sorry but that's all I could find. Mine was set from the factory.
Pretty sure if you don't have the EVIC, then there's no way to adjust it without the dealer using the scan tool to do it. Another idea would be to find a cluster with EVIC and upgrade yours, along with the steering wheel switch and then you can set everything like in your Sahara.
