bussman fuse tap
bussman fuse tap
I am looking at getting bussmann fuse tap to power toggle switches. First question : there are to types ATM and ATC, which do I need. Second question: how many toggle switches can I power with one.
What Bussmann fuse tap do you mean?
ATC and ATM refer to fuse sizes. ATC are the older automotive fuses. ATM are the newer smaller fuses. The TIPM in the JK uses the smaller ATM size fuses.
True. The relays only draw about .1 Amp. If you have illuminated switches you have to include them in your calculations. Switches with LED illumination will use much less current than switches with incandescent bulbs.
60 lamps = 15 amps
60 relays = 6 amps
That = 21 amps.
So you say that I went over 1amp. Ok lets see someone with 60 relays and lamps.
